- Jul 18, 2017
- 16,783
- 5,424
- 50,935
I am aware that the MIRO of a caravan includes everything in it as it comes from the factory which includes the waste master if the unit has an onboard tank. In the Buccaneer owners handbook it states that the MIRO is the weight as the caravan leaves the factory plus 10kg per gas bottle as per the number of connections on the regulator.
In addition, it includes 20kg of gas, EHU cable and should include fresh water if the caravan has an onboard tank. The EU directive refers to 90% fresh water in the onboard tank, but surely the hot water boiler can be regarded as an on board tank?
However a bone of contention is the amount of fresh water you can carry water if for instance you have a 40 litre on board tank. Can you carry the tank 90% full (36litres) and is it included in the MIRO as per the NCC? In the Elddis Buccaneer Owners Handbook it specifically states that the MIRO is calculated with no water on board or in effect it is also excluding the water in the heating system.
Seems to be a conflict here between the NCC and Elddis statements?
