- Mar 14, 2005
- 19,192
- 4,374
- 50,935
GPS only allows you to identify your position on the earth in terms of coordinates. It does not plot it on a map. The plotting of your position is done by the satnav unit which has to have access to map information to be able to display it.
Sat navs either have mapping data built in to them, or it may be necessary to have the mapping data on a memory card that you plug into the unit. Some units can also have a database which incorporates or can Of Interest (POI's) There are many different POI data sets which can be obtained for covering all sorts of POI's.
Unlike pure satnav devices, above, Smartphones don't have to have the map or POI data sets stored in them, they can use their ability to connect to the internet to use online mapping and POI databases to provide the image you see on them. Some systems allow you to download the relevant area of the mapping data to your phone if your likely to loose internet connection.
The GPS signal is entirely separate to the Internet signals (i.e. G3, G4 and G5 used by mobile phones)
