- Jun 20, 2005
- 19,945
- 5,253
- 50,935
The bathroom sky light uses those spring loaded handles for opening and closing.
The tiny securing screws go into very small lugs moulded into the main frame. One broke off, barely 6mm in diameter. Result a whole new frame is needed requiring total removal from the roof, replacing and resealing. Parts alone from Bailey are £179.00 :woohoo:
I managed to drill through the frame with a 2mm drill in the dremel , glue the lug back into place and using a longer screw all is well. If that breaks I may get away with a small nut and bolt.
These lugs are tiny and take the full spring pressure of opening and closing the sky light, plus the force of high winds in bad weather.
A pretty poor design imo
