Hi Have you got the make and model of the motor mover that would help no end thanksI have just purchased a used motor mover but I would like to replace the wiring cables does anyone know the wiring spec I need thanks
Hi,You need 7mm/2 (seven mm squared).
Both cables need to be the same length so you will have a spare coil of the wire from one of the motors when finished.
Then go to the next size up - start-up current can be quite high for movers.Hi,
What an odd size of cable - it's non standard. Find it difficult to understand why any manufacturer would select such a cable.
Hi,Then go to the next size up - start-up current can be quite high for movers.
Hi Leemallin,This might sound silly but I have got loads of household wire could I use this ??
Thank you what amp wire do I need sorry to keep askingAbsolutely NOT !!!
The right item is available here: https://www.ebay.co.uk/itm/Single-Core-Stranded-Wire-Cable-12v-24v-Thin-Wall-Wire-All-AMP-Ratings-11-Colour/123769085583?_trkparms=aid=555018&algo=PL.SIM&ao=1&asc=20190212102350&meid=ceda73e741464609a80446955b6781bf&pid=100012&rk=6&rkt=12&sd=111304360621&itm=123769085583&_trksid=p2047675.c100012.m1985
