motor mover fuse
Sep 24, 2021
Hi I'm about to fit a used powertouch mover, in fact two as its 4WD on a twin axle.. there are no fuses supplied.
Should I fit one fuse in the live cable to the isolator? If so what value as it is supplying 2xmotors.. or a fuse in each live cable to each controller (again what value?)
Thanks..
1,819
It needs a fuse somewhere but the location may depend on the model. I would look up the makers website and see if there is a manual on there.
4,335
The movers manufacturer instructions will tell you what safety devices are needed.
5,252
We have the Powertouch AWD which was fitted by Powertouch themselves and there is a whacking great big 20amp fuse inline on the positive cable.
Oct 17, 2010
1,321
567
19,435
I have a single axle Move Master Motor mover and that has a 80 amp inline fuse, just before the Isolation switch, in fact it looks like a small Buzz Bar. It's a wonder yours doesn't keep blowing B'man
5,252
I have a single axle Move Master Motor mover and that has a 80 amp inline fuse, just after the Isolation switch, in fact it looks like a small Buzz Bar. It's a wonder yours doesn't keep blowing B'man
I would have thought that 20amp would be more than suffcient. At 80amp damage may occur befroe fuse blows? I don't know to be honest.
9,073
Van supply has a 20 amp blade fuse. link given, by Audi. above for a twin axle shows a 125 amp fuse. I will scan my diagram for your appraisal
Sorry I should have quoted Buckmans post as it was that post I was replying too.
4,335
A 20A fuse does seem very small considering its being used for a motor mover. I suspect most caravan mover motors would pull 30 to 40A for each motor each when stalled, which would easily cause a 20A fuse to blow.
However Some mover manufacturers have provided control systems that employ a "soft start" specifically to reduce the peak current demands of the motors when starting from standstill. I'm not certain how they have enabled this, but perhaps that might allow just a 20A fuse to carry the motor loads.
