tonybur said:
Sorry Dusty,just answered the question. However,I'm afraid your incorrect. Just because a car passes an MOT does not mean it's fit to be driven on the road. Failing an MOT also does not mean it is unfit to be driven on the road,the MOT is a test of the vehicle to a very low standard. The pass and fail criteria can be jaw dropping.
wont be long now before someone posts a link from the gov website to give a definitive answer and then someone else will say it is wrong.
always happens,
however my two pence worth is,
1. you can present a vehicle for a test, at any time, but up to one calendar month before it is due. if it passes you will receive a 13month certificate, and the previous certificate will be updated.
2. if it fails you have 10days to represent it for testing without a fee,
3.if it does fail, and there is more than 10 days left on the old certificate, the tester will not issue a fail on the national data base, as there is a current certificate on going [ie there is no mechanism for cancelling a certificate early] he will however issue a paper certificate showing the faults.that require attention.
4, if the vehicle is out of test on the day it is presented. and fails you can drive it to a place of repair, and back to the station for retest, but nothing else,
5. the test certificate although valid for 12 months, only guarantees the vehicle is road worthy at the time of the test and cannot be relied upon for road worthiness any time after the test,
6. if a vehicle has a fault or faults that at the time of the test that are considered to be ok on the test but might cause concern later, advisories will be noted on the certificate, these must be fixed before the next test.
now feel free to tell me i'm wrong, some one usually does, :lol: :lol: :lol:
