- Feb 4, 2014
- 346
- 0
- 0
ProfJohnL said:CyberCynth said:ProfJohnL: Thanks for your comprehensive reply; I really must treat myself to a set of bathroom scales and check the noseweight of my Gobur. I have just looked in the handbook for the noseweight, but can't find it, but I seem to remember reading somewhere that it's ridiculously low, at about 50kg. With two 15kg gas bottles that's over half my limit. Yikes. (However it does say the MIRO includes a 20kg gas bottle, the EHU lead and toilet flush liquid.) The Gobur feels as steady as a rock when towing, the only time I've had a slight wobble was in very high side winds, so I'm hoping my gas box contents are not too excessive.
It would be very unusual indeed for a caravan manufacture to give you the "noseweight", All they can possibly quote is the maximum nose weight the hitch can endure, and possibly,the ex works nose weight. You will find the maximum nose weight on the data plate for the hitch ( thats and EU requirement). The ex works nose weight is of very little value because as soon as you put anything into the caravan the nose weight will change. You have arrange the items in the caravan to trim the nose weight to what you want.
The caravan industry suggest you should aim for a nose weight of about 5 to 7% of the caravans weight. For convenience use 5 to 7% of the MTPLM. However do not exceed the manufacturer's maximum nose weight limit.
Right, Prof, have at last got the right end of the stick.... Looked in the leaflet about the Skoda, and that's where I'd seen the 50kg noseweight figure. So, I will have to be sure to weigh what I have in the front locker and ensure I'm not overloading. But, as have said already, and happily, my ex-Gobur owning pal Gozza concurs, these folders are as steady as a rock on the road, I don't think I can be doing too much wrong.
