Could anyone give me a quick run-down on how to use a Multi Meter. All I want to use it for is to check batteries and fuses. Thanks in anticipation. Ken
We are not talking of something that is as dangerous as a chainsaw, and if we were, I would probably offer the same advice, learn how to use it safely.jignc said:Sorry you are 100% wrong.
If you do not know how to use a tool lets say a chain saw is is very unwise to try and use it with out the correct training. Now a Multi meter will not chop off your leg but unless you have an understanding of how to use it the risk of electrical shock or fire due to trying to measure 240 volts on the ohms setting or current setting is a high risk.
The only way to find out how to do anything is to read the instructions and seek help. If someone was to ask how to drive a car I would point them to where they could the information required to find a driving instructor, I would not try and scare them witless.jignc said:To obtain the level of expertise required to use a mulitmeter safely will not come from a reply on a forum and that is the advise given. It's like saying on a forum how do I drive a car and expecting a reply that will enable you to go out and be safe on the road.
jignc said:The advice given was right make sure that you know how to use a multimeter safely before trying to use one and advice on a forum will not be good enough to do this.
kennygee said:It seems as though A can of worms has been opened up. I consider myself to be quite technically minded and do most of my plumbing, joinery, small electrical jobs, bricklaying etc. What I really wanted to know was in what position do I put the dial on the Multi Meter to check fuses and also to check the strength of my battery(Iies). Don't think that would be classed as dangerous.
