On return from our excellent bank holiday in the yorkshire dales, we used the A1 south from just below scotch corner to the M62 and ecountered major stability problems with our outfit. The van was rocking and moving, and swinging around all over the place which ment I was forced to travel at 45 - 50 mph on this strech which is not a problem untill you realise just how many lorries go past you on a busy motorway!
This is the first time I have used my latest tow car with my caravan and all the checks the made before setting off - ie tyre pressures on car and van, proper packing, correct placing items around the van - all the same as every other time we have towed.
The car is a 2003 Mondeo TDci and the caravan an older one weighing approx 1100kg. I previously pulled this with a 1996 vauxhall vectra with no problems what so ever - the rear suspension was uprated though!
The only indication as too why it was such a poor journey could have been that, behind the towing hitch where the large rubber sleeve hides the spring for the braking was fully closed and could be opened or closed by hand - this is not right as it should have more tension in it.
I watched many other vans overtake me with no apparent problems so any ideas would be appriciated
