New battery
Aug 17, 2019
106
18
4,585
Thinking of changing my lesure battery and been told AGM batterys are a good option but do you need to change the charging system if i change or swap batterys
Sep 29, 2016
1,793
208
Hi Plug, there may be pertinent information for you within the following links:
Most caravan battery chargers are not ideal for AGM batteries.
Link 1
Link 2
1,850
6,935
Wow Link 2 lets a few ferrets lose.
Yes, but it made believable reading I thought.
For reasons I won’t go into, I had a spare AGM starter battery. My granddaughter’s husband said he was having problems with the battery in his Jag X type. We don’t think that the original was an AGM but my battery was going spare so he put it in. We are now about a month later and he says the car is starting better than it ever did. But reading that link, it may be shortening its life. However, that’s better than it sitting in my garage doing nothing.
Reactions: JezzerB
Ern
May 23, 2021
455
211
935
Recently replaced our wet battery with AGM from Tayna Batteries. Wanted a sealed battery more appropriate for location in the habitation area (no vent tubes). No changes required according to advice from Tayna.
3,106
Your set up with no vent holes is contrary to all best advice.
Ern
May 23, 2021
455
211
935
I don't know about "all best advice" but there are 100's of 1000's of motor caravans with sealed AGM leisure batteries in the habitation area. AGM is better than wet.
3,106
Just becasue there are many instances of a characteristic does not make automatically the correct of safest way to do it. There are 100's of 1000's drivers who speed - it doesn't make it right or sensible.
2,072
There are 1,000s of premium SUVs with an AGM battery in the passenger compartment under the passenger seat, eg VW Touareg, Audi Q7, Porsche Cayenne.
But caravans don't "need" an AGM battery, a EFB works quite adequately.
6,240
Are the AGM batteries in “ premium” vehicles starting, stop-start or do they fulfil a separate function. My son had a Defender some years ago with a lead acidic battery under the drivers seat. Can’t recall if it also had another in the engine compartment too.
2,072
The 5 litre diesels have twin batteries and separate various functions but the "smaller" engined models just have a single internal AGM battery covering all functions, including stop-start.
1,850
6,935
My Volvo has two AGM. A large starter battery and a motorbike sized one. I know it’s to do with the start stop, and have been informed it is to prevent hiccups with lights, radio etc when it starts. Other cars with start stop only have only one battery. I suppose it is to do with however it was designed.
3,414
32,935
Our Jeep does not have the stop start function. Last year I required a new battery and had it fitted by the "experts". Later the Jeep went to the Jeep dealer for its service and it was picked up that the incorrect battery had been fitted. The fitter at the battery shop had fitted an incorrect AGM battery.
The battery fitted was for stop start, but apparently it had an effect on some of the systems in the Jeep. It was changed for the correct AGM battery. AGMs are fitted inside vehicles in case of a roll over. No one wants acid pouring down on top of them!
Aug 17, 2019
106
18
4,585
So reading all the replys and thanks for them the outcome is that a AGM battery in a caravan has no improvement on a standard leisure battery
Ern
May 23, 2021
455
211
935
If your battery is located in a separate enclosure to the habitation area, then there is no point to my knowledge. I chose AGM because my battery is located in the habitation area. AGM are more suitable for this.
3,414
32,935
Just to add we forgot to turn off the 12v and ended up with a flat AGM battery and it stayed like that for about a week. We then recharged it from about 6v land it is still going okay.
6,240
I would not say , it's pointless, As if it is an AGM then there are no acid levels to check , and removal of my side fitted battery is a Pain in the bum.
Not many people have to check battery levels on modern lead acid cells. Even my Banner which wasn’t “ sealed” was only checked twice a year and had not required a top up in two years.
But removal is a pain and a slide out shelf would be good. Although weighing more than the maker supplied apps of dubious utility.
