I have owned a Bailey for 6 yrs and changed it for the new Series 5 Pageant Monarch in January 2005 (ordered in July 2004). It took six months to get the caravan due to dealer error in order.
At pdi instead of one hour suggested time to check over it took 3 hours to have items we noticed corrected or recorded for replacement(lights not working, tarnished light fittings, no carpet fixings to floor, missing cover caps to wall panels in bathroom area, and this does not include the problems of extras I had fitted that were left unfinished). I thought after 20 years of caravanning that I would have been able to carry out the pdi inspection quite well. Be warned, Baileys quality control is not as good as it used to be. Within the first three weeks I noticed a bulge in the side of the van where I am informed the floor and the wall panels are not properly lined up. My dealer and Bailey 'advise' me that this is not a problem, and pointed out that if there was a problem it would be covered by the 6 year warranty ( not much confidence in their opinion). Bailey state that this is not a common problem, but they had also indicated via the Dealer that this may occur in say 1 in 60 new caravans ( I assume of any of their range). I have also found one fixing clamp holding a high level cupboard onto the wall was broken and had not been repaired during manucature, the cover cap having been placed in position, hiding the broken fixing. Also when opening the table for the first time found that the stays were bent and the table would not stay up.
If you do buy a Bailey (and I suppose this would also apply to any caravan make), check the condition thoroughly, check every piece of equipment to see that it works, and if necessary take every cover piece of every fixing bracket to check whether it is broken.
I will next week when I go and collect the caravan to see if everything has been corrected.
