Beachball has recently had a new control panel fitted and a new leisure battery.Hi Beachball, I think your van has the Nordelettronica power system and it would seem that it has done what they are known for,,,,,,malfunctioned.
I would just check to see if you do have the Nord system, and if so, give Paul or one of his team at Apuljack Engineering a call tomorrow.
Here is the info to contact them: http://www.apuljackengineering.co.uk/contact.html
Yes we do have the Nord system . I have check the details out and if we need Paul i will ring him thanks .Hi Beachball, I think your van has the Nordelettronica power system and it would seem that it has done what they are known for,,,,,,malfunctioned.
Hi,At present we have these working Sockets , Microwave , Tv 2 Lights
i have checked the MCB the lever was up so it had not tripped
i have retested it to make sure .
the fridge , water tap spotlights toilet flush is a no go
is there something i am missing ?
Actually we check the battery fuse that was ok but we are home now after the quickest 14 day break only had 2 days . the caravan going in tomorrow and i leaving it with him until he check everything on the 12volt systemHi,
Circuit breakers only protect ac circuits not dc circuits.Check your fuses in particular the battery fuse (Usually rated at 20A and located near the battery box) dc circuits are protected by fuses might as well check them also.
To check your Nord thingy if you can put a voltmeter across the battery then switch on the nord unit - the battery voltage should go up,not a lot but it should go up
Hi Hutch Actually we are hoping we can transfer it to bit later in October i might send a email or ring in the morning see what they say .Thats not good news for you, hopefully Rutland might give you a credit to go back another time.
