when connecting the hose from the caravan to the fresh water barrel and when it is in the barrel it floats to the top,so i need something to give it a bit of weight to hold it in the barrel,any suggestions,Thanks,
SORRYEddie
You should have a water pump at the end of the pipe. Its a complete item witch plugs into the side of the caravan. One end a plug/ socket pipe with water pump on other end. You have a new sprite alpine the dealer should have supplied this item and showed you how it works.
Hope this helps Steve
80 mm pump connection, available for both capacity Aquarolls 29 and 40 LitreEddie, you need Aquaroll's cap with an integrated tube down which you slide the suction pipe so its located at the bottom. It works a treat.
Look at this web page, well down on it you will see it as a "Connection"
http://www.aquaroll.com/english/accessory.html
Cheers John
