New to caravanning! Silverline Pegasus 1989 renovation questions
Aug 24, 2025
8
Hi everyone! I very impulsively purchased a Silverline Pegasus 1989 with absolutely no knowledge about caravans or caravanning and I'm very quickly learning I am *completely* out of my depth! I'm completely clueless but eager to learn and willing to turn my hand to DIY and tinkering. I bought her as a project... And a project I have indeed got!!!
We are willing and able to put in the graft to get her right but we have damp issues and holes galore, and inherited problems such as a broken heater, taps not working and the oven won't ignite.
Please bear with me on this line of thought and my query... I think our first job is getting her watertight. We have pin hole damage to the walls in the back nearside corner so we're thinking we need to rip out the kitchen as the walls are rotting. Possibly the floor too but we don't know til we get the kitchen cupboard/sink bit out and look. Our kitchen has a sink, hob/grill (apparently this is working and would be good to keep, fridge uses gas too I believe) and an oven (ignition apparently doesn't work but this was what I was told by previous owners).
As the kitchen taps don't work, I'm wondering whether to fully replace so we know we're all good, which then led me to think if we actually need the water heater...
Just to reiterate, I have absolutely no clue about these things but I've been reading some threads and watching youtube this morning, we have a cascade 2 and truma. I'm wondering that as we don't intend to use the shower in the van, we'd only really need hot water for a bit of washing up i.e. Either washing dishes or our hands/faces. We are thinking that if we can get her ready for adventures, it'd be more of a glamping pod than "luxury caravan with all the mod cons" and would use shared facilities on sites.
Also as the heater doesn't work (no idea why, old owners said it hasn't worked for a while) this would need replacing.
As it's all connected to the gas or each other in one way or other and the whole system (I'm assuming) is connected together, I guess what my query is, is it as simple as "just ripping out the kitchen" or do I need to factor in these other appliances before we start dismantling the kitchen?
Any advice would be greatly appreciated, would love to hear from anyone who has completed a full renovation!
9,363
Hi welcome to the Forum, you’ve certainly dived into the deep end from a 10m board.
There are some on the Forum who have resurrected old caravans and I’m sure you will get good advice. Some pictures of the various areas of your caravan would be a good starting point. Post them into a new thread such as Technical.
5,387
It reads as if you have severe damp and damp is the most important issue that needs to be resolved first and foremost. Have you do a damp check using a meter damp meter? Do this before spending time and money trying to fix the caravan.
Aug 24, 2025
8
Morning! Thanks for replying! Yes, I've bought a damp meter and the internal wall that has the most visible damage appears to be more or less dry, though completely crumbling and rotten. It's the back corner next to the sink. The cupboard underneath the sink where this wall continues was maxing out the damp meter but by airing it out in this dry weather, it has reduced the damp significantly. I believe the cause for the damp/rotten wooden is due to holes in the aluminium skin where it's corroded.
Aug 24, 2025
8
Thank you so much for replying! Yes haha! It very much feels like that and reality is setting in - it seems I didn't bring my armbands and I'm hoping this forum might lend me some hahaha!
I'll pop a post on there, fingers crossed I'm a quick learner!
5,387
Not sure if you could repair aluminium as it normally requires a professional. The corrosion normally happens where there is bad damp. The nails holding the frame together rust and the rust reacts with the aluminium causing corrosion. On one of one caravans even the dealer could not do a repair which is why we traded in the caravan. The whole side would have required replacing and this was a 2011 caravan.
Aug 24, 2025
8
Oh blimey, that sounds like a right palava! I guess I just need to get the kitchen out and see what damage we're actually faced with huh? I was wondering if I could treat the holes (someone historically has painted over some which seems to be hole-ding up around one of the side windows (see what I did there) and then fill them with epoxy putty and then reinsulate and reboard and rebuild the kitchen. There just so many things swirling in my head I think I've got myself in a twizz!
5,387
You could try that, but not sure how well it will blend in with the rest of the caravan and whether more will appear at a later stage due to current damp etc. One needs to be careful as you do not want to spend a load fo time and money only to find out that it is not viable in the long run.
Unfortunately none of us know how good or bad the condition of the caravan is. It may be worth paying a caravan engineer to give it the once over and to advise whether restoration is possible. Probably cost about £100 but in my opinion money well spent and it could save you a lot more. Your decision.
Reactions: peggysue
Aug 24, 2025
8
Appreciate your advice! Really do, wish me luck!
Reactions: Buckman and Hutch
2,638
Hi peggysue Welcome to the forum hope you enjoy your project keeps updated with pictures how you are getting on and good luck
Reactions: peggysue
Sep 23, 2023
1,431
636
2,435
Welcome aboard,it would be worth having it checked for dampness as advised above,the timbers are an important part of the caravans structure and any rot will adversely alter the structural integrity,to replace rotten timbers can involve the removal of cupboards, wardrobes etc,they themselves are another problem to remove,they are usually fitted from the outside in and not from the inside.I hope all goes well for you,if you undertake the renovation there are forum members who can help,I myself have a 1992 Abbey which I've nearly finished renovating and I have a large selection of images on what and how I've done mine,all you need to do is ask. Gary
Aug 24, 2025
8
Thanks so much for your reply! Approx 1 hr before your msg we found out the hard way that the cupboards are fitted from the outside in, eeeek! The walls at the back are damp and right in the back corner behind the wall cupboard so it had to come down sadly. No point cutting around it. If we're gonna do it, we may as well do it properly eh?! Will be sure to check out your posts, I'm already learning so much!!
Reactions: toad a caravan
Sep 23, 2023
1,431
636
2,435
It would be advantageous if you can find the source of the water ingress,it could be a awning rail joint,..There is the awning rail itself,two seals on the outer edge of the rail that locates between the rail and body, screws to hold the rail to the body, plastic Herzim strip (Usually colour coded matched to the caravan detailing) that covers the screws and finally there is a bitumastic sealant applied between the rail and body,,this eventually fails,Overtime this sealant should be removed and replaced(recommended between 10 to 15 years ).I have done mine and posted images in the vintage section of this forum. Gary
Reactions: peggysue
Aug 24, 2025
8
So after doing some more dismantling, it would appear it is indeed the awning rail and every rail and window seal where we have ingress *DOH!* Needless to say, we're currently on with the arduous task of removing all the rotten wood and then plan to repair the aluminium skin, build a new timber frame (all the framework has rotten to damp dust where the rails screw in), remove all the aluminium rails, clean them up, get them resealed with mastic (what are your thoughts on sikaflexing them once fitted to??) and install new herzim strips.... The offside awning rail is completely missing it's herzim strip so no wonder the bathroom walls are rotten *facepalm*. The previous owners said it'll be a little refurbishment, how naive I was! Hahahaha
5,387
I would avoid using Sikaflex in case you need to do a repair at a later date. Hopefully you got the caravan for a song?
5,467
That’s very interesting and a new one on me Ian😉
I will stand corrected but for years I have always tried to use the same proven materials as the oem. Plus the major repairers swear by the two following sealants. Both have excellent adhesive properties. They do not harden and as I can confirm my skylight was still water tight and the sealant still malleable after 15 years
The only two sealants I have been told to use are
Sikaflex 522 or Soudal RV 61.
I have used both and have no complaints about their performance or durability.
Have I missed a trick 🙀
Apr 23, 2024
586
475
1,135
@Dustydog IMO No , I use Soudal Fix all or Sikaflex 522, when making repairs , after seeing how the 'non-setting' mastic which caravan manufacturers use has been mis applied ( gaps )or has failed - The front window hinge bar on Elddis Xplores -the weight pulls at the mastic , dirt gets in reducing its 'stickiness' allowing water into the framing being a case in point along with numerous awning rail seal failures. To remove the Soudal/Sikaflex I use a combination of a hard nickel 'cheese' wire and sharpened paint scrapers.Also the non-setting mastic actually hardens over time and if excess applied, goes black
5,387
I am sure that it was Sikaflex that they use to glue down our satellite dome. It was impossible to remove the feet.
5,467
It could well be . There are numerous types of adhesives in the Sikaflex range. Do you know which one?
5,387
No idea, but my post was to advise the O to be cautious about Sikaflex obviously depending on which one was being used.
Sep 23, 2023
1,431
636
2,435
This is the sealant I've used on all my aluminium rails,It's what was used on mine by the manufacturers in the timeINFO FORUM _064411.JPG,if I remember it was made in Hull,it allows for expansion and contraction of the joints it's non setting and remains flexible for approximately 10 years possibly more. AWNING RAIL ADHESIVES_071538.JPG
