Daddyo1. said:Hi My caravan weight is 1540Kg and I was looking at the Skoda Kodiaq 2.0TDI front wheel drive and a KIA Sportage 2.0crdigtline
Woodentop said:Look for the comment about a Passat AllTrack from LeedsLad on the CaravanTalk forum. Being a Passat (estate) user myself I know how good it is, so with the 4x4 version I doubt you would ever get stuck. The max tow capability of the Passat is 1800Kg, oh, and the Kodiaq is built on the same chassis.
As confirmed by a Skoda dealer last week, the Tiguan is built on the Golf chassis, as is the Octavia. The Kodia, Superb, and Touareg are all built on the same chassis as the Passat.Icaru5 said:Woodentop said:Look for the comment about a Passat AllTrack from LeedsLad on the CaravanTalk forum. Being a Passat (estate) user myself I know how good it is, so with the 4x4 version I doubt you would ever get stuck. The max tow capability of the Passat is 1800Kg, oh, and the Kodiaq is built on the same chassis.
I have the Passat B8 estate and the max. towing capacity is 2000KG, although the Kodiaq is probably more than this, as if I’m not mistaken it’s a Tiguan in different clothes which whilst they share the same MQB platform as the Passat I think is rated at 2200KG - In any case this figure of course isn’t relevant as there’s no way you'd be anywhere near even the 1800KG of the older series Passats. Outfit matching and correct loading are of course the relevant factors here.
Keeping back on topic, my Passat tows a fairly heavy van just fine, although where a four wheel drive vehicle would make a real difference is when trying to set off when trundling through muddy farm land after packing away, or when pulling out of farm land into main roads. It’s nothing to do with power or towing capacity. Without an LSD you only need one of the front wheels to loose traction and you’re going nowhere because all of the power is then being applied to the spinning wheel. Neither of these are a huge issue, and I would much rather eat away the motorway miles (non-towing) with the Passat than in many of the four wheel drive alternatives that are considered to be better suited to towing.
However, the OP does make reference to a “Tow Car” and if towing was the main consideration, rather than a daily mile cruncher then I too would be seriously considering four wheel drive for the reasons mentioned above.
I’m sure the alltrack would be great. Best of both worlds if the budget can accommodate it ...
Ic.
SamandRose said:Icaru and Woodentop - my understanding is that the new (2016 on) Tiguan is built on the MQB platform - as is the Kodiaq, Passat and almost everything made by VW, Audi, Seat and Skoda from Golf-size upwards.
I have a Passat B8 as well (and have had the B6 and B7 models before that). It's brilliant and I would go for another over a 4x4 SUV in a heartbeat. But that's because, like you, I use it as a mobile office first, personal transport second and a tow car third. If I did more towing and less business mileage I might be tempted by 4WD. I understand that the 4WD system used in the Passat Alltrack, VW Tiguan and their Skoda equivalents is identical so, with the possible exception of ground clearance, there should be no reason why any one of these is any more or less capable in the mud than another.
I guess it's just nice to have the choice! 🙂
EH52ARH said:SamandRose said:Icaru and Woodentop - my understanding is that the new (2016 on) Tiguan is built on the MQB platform - as is the Kodiaq, Passat and almost everything made by VW, Audi, Seat and Skoda from Golf-size upwards.
If your stuck in the mud, then its the type of tyres you have that will get you out, not just the 4WD.
