Newbie
Aug 12, 2023
652
302
2,135
Being a marine starter battery, large clamp terminals go to motor. Smaller bolt terminals are for electronics eg deep sounder, radio. Yuasa is very good brand.
Not the ideal battery type for a caravan but will do the job. AGM deep cycle battery would've been better and probably cheaper option.
19
Someone sold me it on the site that I'm on for £40 the only thing I use it for is my water pump
4,470
Some motorcycle batteries also use the two terminal systems. Two tapered and two bolted, terminals.
Here is a leisure battery from Tanya.
5,197
Here’s my old Numax replaced it with a new one a few months ago. Both have four posts. Never gave it a second thought other than different caravans wiring use different connections maybe. Or was it for direct connection to the fridge 🤣🤣🤣
Reactions: toad a caravan
Mar 3, 2022
392
310
4,935
Last NUMAX had the double posts as does my current X-PRO.
I've wired up 2nd set for use in running an inverter for charging a mobility scooter, flag pole lights etc.
