When I tried to find a replacement for our temperamental Omnivent, I was told it was the only fan that fitted the 400x400 mm roof aperature - although plenty of choice of skylights that size without a fan.I think the extractor is probably the Omnivent?
Yeah if we manually try to start the fan it goes but then stops my husband suspects the motorWhen I tried to find a replacement for our temperamental Omnivent, I was told it was the only fan that fitted the 400x400 mm roof aperature - although plenty of choice of skylights that size without a fan.
For the OP, the more you persevere to get the fan started the more reliable it becomes - at least ours is!
Is it a case of describing as omnivent motor required no need to give caravan deets etc?? Thanks xIs it flashing light syndrome? Switch it on and the lights just flash side to side?
If so in all probability it's the motor on the way out. You can buy replacement motors fairly cheaply from the likes of eBay and they are easy to fit.
It seems the motor we think but thanks for replyingWhen I tried to find a replacement for our temperamental Omnivent, I was told it was the only fan that fitted the 400x400 mm roof aperature - although plenty of choice of skylights that size without a fan.
Generally not the motor, but the switches. These are the touch type switch and what happens is that damp gets into the electronics. This may sound silly, but sometimes hair drier cures the issue, but be very careful as you do not want to melt the plastic surround.Yeah if we manually try to start the fan it goes but then stops my husband suspects the motor
Hi Hazel welcome to the forum i would give this a try Leisureshopdirect
i think they might have one in stock
Elddis Caravan Spares | Leisureshopdirect
Elddis is a caravan and motorhome manufacturer based in Consett, Durham, which has built an empire from a simple and effective prototype. From its inception in 1964, Elddis has been a front runner inwww.leisureshopdirect.com
Ours is not touch type or with lights it is on / off switch if you know what I mean as far as we can see the switch is okay it’s just motor not performing and noisy. Has been removed now looks very rusty maybe had damp at some stage before us??Generally not the motor, but the switches. These are the touch type switch and what happens is that damp gets into the electronics. This may sound silly, but sometimes hair drier cures the issue, but be very careful as you do not want to melt the plastic surround.
Yes everything clean and now motor is out it is rusty as if been wet we have sourced a new motor local to us on eBay thanks to everyone for all your help 😃I assume the whole fan and surround is clean and it is not an accumulation of dirt debris messing things up?
If all good and clean spray the motor and contacts as best you can with Electrical Contact Spray. It may work if not I agree a new motor is needed.
Glad you were able to get the perfect item you wanted, Ebay is an excellent source to go to when you want something with reasonable prices if you look carefully.Yes everything clean and now motor is out it is rusty as if been wet we have sourced a new motor local to us on eBay thanks to everyone for all your help 😃
