Feb 9, 2009
465
24
18,685
At the moment the 12v is not working. Battery is fully charged and has been checked away from the caravan by a mechanic.
One of the 15amp fuses shows as van batt+ and I will go back to the van tomorrow to change it but does anyone know if there also an in line fuse between the battery and the vans circuits ?
The van is a 2010 Lunar Ultima TL(Lexon TL)
Jul 15, 2008
3,647
673
........most caravans have a main 12 volt fuse in the positive feed wire just after it enters the caravan from the battery box.
From inside the caravan access the rear of the battery box.......locate the supply wire and trace it to find the fuse.
Jun 14, 2009
75
I had a similar problem on my last trip out. The 12v in-line fuse looked good BUT the spade connector to the fuse holder had shaken loose!
