- Aug 9, 2011
- 3
- 0
- 0
Hi all.
I would appreciate any help that you can give regarding the water system on my 1995 Abbey Spectrum.
I cannot get hot or cold water to the taps.
I have tried the following -
Are there any other filters that I don't know about that need cleaning / changing. Is there anything that could cause a blockage ?
- Removed the tubing immediatley after the tank and pumped water so assume the internal pump is working satis.
- Blown down tubing to remove any airlock.
- Removed and cleaned the diffuser in the mixer tap.
- Changed tap washers.
- Cleaned inlet into pressure switch.
