So, I'm at my wit's end. After the very cold snap before Christmas last year, I can't get water out of the taps or shower in the caravan (Bailey Unicorn Seville 2011). The heating was on low during the big freeze (and the water heater sits right next to the Whale AK0814 pump under the bunk). A water barrel was attached, but I didn't ever try to draw water while the weather was cold just in case it had frozen in the water container. [I use the caravan as my office during the day].
After the freeze, and when the temperature had increased, I switched on a tap, the pump came on and threw out a little bit of water and quite a lot of brown flakey bits. Then nothing. The pump still runs. No water.
I've checked the outside water fittings (a pipe into the water container with a filter on the end which connects by a socket into the wall of the caravan). I've replaced the rubber washers on the socket too. I've also tried pulling water from the internal water tank, in case the problem was the external pipes. Again, the pump runs but no water appears - just a bit of airy spluttering when any tap is open, and a few more brown flakes!
I took the pump head apart and cleaned it (it wasn't very dirty at all) and looked OK. I tried again. Nothing. No water. So I rang Whale who suggested I try replacing the pump head. I fitted that today - still no water, just spluttering from the taps, just a Tsssssssss sound and the occasional gurgling (both when the internal water tank and external barrel are connected).
I checked the impeller of the motor, it's turning fine and so should be driving the new pump head. I can find no leaks in the pipework. It's very weird. I wonder whether the new Whale pump head was faulty (but that doesn't seem likely). When I run the pump (briefly) with no water pipes connected to it, there's very little suction from the inlet and nothing much from the outlet either.
The Aldi heater still works fine for the heating (an anti-freeze based system).
I'm out of ideas, and getting quite frustrated by the whole thing...!. Any thoughts would be really helpful. Thanks
