Nose Weight (Just cant get it low enough)
Aug 5, 2016
Hi All,
Hoping for a little advice. I have a Fleetwood Garland 128/2 little 2 birth van. Both my tow car (Volvo S40) and the tow bar have a nose weight limit of 75kgs. Problem is that I can't get the nose weight down anywhere close to it even when the van was empty. I have removed the spare wheel and placed this in the boot of my car. The small awning is over the axel in the van and the only thing of any weight in the front compartment is the small gas bottle. Even with this removed the nose weight was still 117kgs. Any advice?
Apr 20, 2009
5,630
1,030
What are you using to check the noseweight with?
Have you checked the gauge(scales) against another compatible device?
is the tow hitch at the correct height with the tow ball?
Feb 3, 2008
3,790
Move the spare wheel and awning to the back of the van (on the floor) and recheck the nose weight. Not ideal, but 'needs must'.
Is the water tank empty? Have you got anything under the front beds?
Aug 5, 2016
Hi thanks a lot for the reply. I am using electrical bathroom scales with the load spread and a cut rod upto the hitch, cut at the height to match my tow ball. The scales seem to work fine when measuring me.
Aug 5, 2016
WoodlandsCamper Yes, the water tank is empty. I have a couple of duvets and sheets under the beds at the moment
1,819
The bathroom scales method is not accurate as the jockey wheel is behind the hitch. I would get a good noseweight gauge and try again. I doubt it will be within 75kg but at least it should give you a better idea of the actual weight.
I would try woodlands Campers suggestion as the only thing left after that.
4,277
Hello Adam,
I have towed countless caravans over the years, some straight from manufactures factories, and others loaded ready for holidays.
Many of the caravans direct from manufacturers do have a high nos load. The solution in those cases was to use water containers put in the rear of the caravan to counterbalance the nose load.
Yes this is end loading, but in most cases it only required 20 to 50 kilos of water to bring the nose load under control. All caravans will be ok with some end loading, but it must not be excessive.
With loaded caravans it usually a question of moving the items around in the caravan.
My suspicions is you have removed too much from the caravan, and you should consider moving the spare wheel to the back of the caravan.
As for measuring nose load, I dispute Rays contention that the bathroom scales method is less accurate than proprietary retail devise. (you will find much about these devises on the forum) But rather than using a wooden post to support the hitch, instead for safety raise the scales on the caravan step and to set the correct height pack it up using magazines. As for accuracy I venture that bathroom scales are more accurate than virtually any other spring based nose load measurement available to users.
Just make sure the nose load measurement is done with the hitch at exactly the same height as when itis coupled to the car. otherwise you are not measuring the true nose load.
Aug 5, 2016
Thank you very much for all the advice everyone. I will have a tinker tonight, ready for the tow tomorrow. Thanks again.
ProfJohnL said:
Hello Adam,
Sep 5, 2016
239
The caravan industry make hard work for the average person to under stand about loading a caravan, simple solution is to revert to road haulage regulations , gross weight , tare weight and pay load which we don't use, in the case of nose weights if you are keeping within the confines of what you are legally allowed to carry on your vehicle I would put any spare weight over the axle use smaller gas bottles, two 6kg gas bottles weigh twenty nine kgs,
2,188
We had a Swift which was very nose heavy when totally empty. Loading just a bit behind the axle sorted it. Tried to avoid loading right at the back of the van, as found, as the Prof said, that moving some weight just back a bit made a big difference.
mel
4,277
One of the problems we have in the caravanning world ( and also for normal domestic trailers) is the plethora or acronyms used to describe various weight related criteria. I don't think it will help the average caravanner to be presented with even more naming variations.
I however agree that the average caravanner does not know about the minute but important differences between some of the commonly used acronyms and how they relate to each other.
Sep 5, 2016
239
I know the feeling having worked in road haulage all my life, EU driving regs, working time directive, axle weights, load distribution, load restraint, and if you don't get all this right you have VOSA breathing down your neck now I'm retired I'm a happy bunny, I think JW did something on this subject on the caravan channel, but with the new series of Practical Caravan TV starting it would be nice to see something practical put together explaining to new comers in to caravanning exactly what is what with the various weight ect with a real caravan and tow car,
40
When necessary I use full 8 litre water containers stood in the toilet room at the back of the caravan. Works well, but if you do this make sure containers are securely capped and stand them in a crate ( full sided not the folding type) and if possible secure with a bungee cord or similar. Being at the back of the caravan they will be subject to considerable sideways forces when you corner, particularly if you have to change direction sharply.
I would also suggest getting an under slung carrier for the spare wheel. Although this won't transfer the weight quite as far back, it will put it very low down which is desirable.Wrap it in a bin bag or similar before putting it in the cradle if you want it fairly clean in the event of having to change it. Don't forget to check the pressure regularly, put it in valve side down.
(Sorry - you probably know much of this already)
Sep 5, 2016
239
When we had the Lunar Chateau which was Belgium built it came with a long A frame, not only that I never had a problem with nose weight because the caravan was that further away from the tow car and giving a better view of the caravan when towing, it would be nice to have a choice of chassis,
40
There is a choce of chassis - in this case with longer drawbar - buy a continental caravan. Most are designed to take a bike rack on the drawbar and they don't seem to worry so much about noseweight and the like.
The longer drawbar does help towing stability - the longer the distance from pivot point i.e. tow ball to main axle the more stable. If you want a demonstration of this try towing a short trailer - domestic style to the local tip and see how easy/difficult it is to reverse.
Sep 5, 2016
239
Good suggestion I will take that on board when I buy my next caravan and buy continental, the Chateau did have a continental build and 'A' frame it even came with a bubble bodywork finish and onboard water tank, it was only Lunar that stuck their name in front of Chateau,
May 24, 2014
3,687
765
The one thing that hasnt been mentioned is "are you measuring the noseweight on level ground". Even a slight forward slope can make quite a bit of difference to the readings.
Like some of the others, I have had vans that I had real trouble with the noseweight, I recall a Swift Milano (based on the old Baronette) that had a ludicrously high noseweight. Switching to calor light gas bottles is a good suggestion, there is a few kg diffence there to start with. Try moving the awning bag to just behind the axle.
Also, consider lost of small items that weigh little can be a staggering weight when put together.
4,277
By the same token, a reverse slope will decrease the applied nose load, so measuring on a flat (horizontal) surface is a critical point, as is measuring the nose load with the hitch at its real towing height, which if it isn't, has the same effect as a sloping road.
Jun 2, 2017
141
yeezy boost 350
jerseys cheap
coach outlet online
heat jerseys
phillies jerseys
cowboys jerseys
hermes bags
discount nike shoes
oakley sunglasses outlet
michael kors outlet store
louis vuitton bags
yeezy boost
mont blanc pen
michael kors outlet
adidas uk
birkenstock outlet
louboutin pas cher
nike outlet
toms
burberry outlet online
kate spade handbags
purs jerseys
adidas outlet store
cheap jerseys
toms
coach factory outlet online
cheap nike sneakers
nfl jerseys
louboutin outlet
longchamps
air max outlet
ralph lauren sale
adidas running shoes
coach handbags outlet
birkenstock shoes
coach outlet online
true religion
pandora charms
fitflop shoes
nike outlet store
ralph lauren outlet
adidas nmd r1
yeezy shoes
air max
nike outlet store
coach outlet online
michael kors
coach outlet store online clearance
hermes bag
kate spade bags
moncler uk
versace
cheap jordans for sale
prada outlet online
ralph lauren outlet online
louis vuitton factory outlet
gucci borse
mont blanc pen
swarovski sale
coach outlet online
kate spade outlet online
mulberry uk
coach purses
jordans
tory burch outlet online
adidas outlet online
giants jerseys
adidas nmd runner
gucci outlet online
adidas nmd runner
adidas outlet store
yeezy boost 350
beats by dre
rolex replica watches
nike outlet
moncler uk
gucci handbags outlet
ralph lauren sale
coach outlet store
kd shoes
cheap jordan shoes
polo ralph lauren outlet online
sac longchamp
burberry outlet store
ralph lauren outlet
kate spade outlet store
harden shoes
pandora jewelry
pandora charms sale clearance
michael kors handbags outlet
polo ralph lauren
christian louboutin
dansko outlet
texans jerseys
ralph lauren sale
fitflops
fendi bags
air max 90
dodgers jerseys
eltics jerseys
louis vuitton outlet online
longchamp bag
rolex replica watches for sale
chaussures louboutin
nike free 4.0 flyknit
rolex watches
coach outlet store
yankees jerseys
montblanc
pandora charms
fitflops sale clearance
pandora
coach outlet online
nike free run flyknit
nfl jerseys cheap
curry shoes
ray ban sunglasses outlet
christian louboutin outlet
adidas nmd runner
nike air max 95
marc jacobs
christian louboutin shoes
adidas ultra boost
ray ban sunglasses discount
cheap jordan shoes
adidas superstars
hermes outlet online
oakley sunglasses on sale
cardinals jerseys
michael kors outlet clearance
abercrombie outlet
marc jacobs outlet
hermes outlet
cheap rolex watches
pandora charms
air max 90
nike free run
nike outlet store online
longchamp handbags
yeezy boost
true religion jeans
ralph lauren sale
tory burch sale
coach outlet online
fitflops clearance
air max
cheap jordan shoes
michael kors outlet online
nike sneakers
coach outlet online
yeezy boost 350
louboutin outlet
coach outlet online
gucci outlet online
air jordans
coach outlet store
discount oakley sunglasses
moncler pas cher
polo ralph lauren
mulberry bags
sac louis vuitton pas cher
coach outlet online
ray bans
michael kors bags
adidas
toms outlet
coach outlet store
michael kors
mont blanc pens
broncos jerseys
sac louis vuitton
birkin handbags
swarovski uk
fake rolex watches
clarks shoes outlet
wireless beats headphones
salomon boots
birkenstock outlet
ralph lauren
jordan shoes
fit flops
coach outlet store
louis vuitton outlet store
adidas nmd r1
gucci
red bottom shoes for women
mulberry handbags
adidas nmd r1
christian louboutin sale
swarovski crystals
ralph lauren outlet
rangers jerseys
mulberry outlet uk
mlb jerseys
true religion jeans outlet
pandora jewelry outlet
fitflops clearance
beats wireless headphones
burberry sale
bercrombie
tods outlet
fitflop shoes
cheap nike shoes
cheap nfl jerseys
kd 8 shoes
salomon outlet
nike outlet online
burberry outlet
michael kors bags
jimmy choo shoes
ed hardy store
fred perry polo shirts
cheap oakley sunglasses
valentino outlet
pandora charms outlet
air max shoes
nike store
dolce and gabbana outlet online
yeezy boost
toms outlet
fitflops sale
michael kors outlet canada
nike roshe one
gucci
49ers jerseys
moncler jackets
mbt
michael kors
ralph lauren outlet
adidas
yeezy boost 350
nike air max
yeezy 350 boost
michael kors bags
ralph lauren
patriots jerseys
adidas nmd r1
michael kors uk
coach outlet online
nike blazer low pas cher
pandora bracelet
nike air max 95
red sox jerseys
gucci bags
coach outlet online
air jordan shoes
nike flyknit
christian louboutin
mulberry uk
moncler outlet online
levis outlet
toms
nike roshe shoes
longchamp soldes
longchamp outlet store
hollister clothing
coach outlet canada
lakers jerseys
kate spade uk
longchamp bags
michael kors
ralph lauren sale clearance uk
moncler jackets
chi flat iron
jordan shoes
hermes bags
polo ralph lauren
mulberry
ralph lauren
clarks shoes outlet
coach outlet online
nfl jerseys
coach outlet
michael kors
mlb jerseys
adidas sneakers
longchamp bags
adidas store
hollister kids
beats headphones
nike cortez classic
tigers jerseys
warriors jerseys
pandora jewelry
salomon outlet
cheap air jordans
longchamp pliage
nike air force
michael kors outlet
louis vuitton purses
michael kors
nfl jerseys wholesale
adidas superstars
packers jerseys
longchamp handbags
fitflops sale
michael kors
red bottom
pandora outlet
white sox jerseys
fitflops sale
mbt
air max
clarks
nmd adidas
cheap ray ban sunglasses
coach outlet online
adidas yeezy boost 350
burberry outlet
cavaliers jerseys
air jordans
adidas sneakers
true religion outlet online
fred perry shirts
adidas trainers
polo ralph lauren pas cher
cheap jordan shoes
pandora jewelry store
red bottom heels
eahawks jerseys
ed hardy outlet
coach outlet online
louboutin shoes
nike uk
clarks shoes for women
parada bags
longchamp sale
yeezy shoes
bulls jerseys
moncler coats
nike outlet store
vans outlet
vans store
timberland boots outle
ray ban glasses
christian louboutin pas cher
cheap jordan shoes
rolex watches
jordan retro
yeezy boost
oakley sunglasses wholesale
nike tn pas cher
jordan femmes pas cher
rockets jerseys
cheap rolex replica watches
adidas nmd runner
montblanc pens
coach outlet online
gucci bags
birkenstock uk
adidas yeezy boost
thunder jerseys
jordan uk
louboutin outlet
birkenstocks
sac longchamp
ghd straighteners sale
adidas yeezy boost
coach outlet online
fitflop
adidas yeezy boost
birkenstock
celine outlet online
air max 90
fitflop
birkenstock outlet
ed hardy clothing
nike sneakers
fit flops
louboutin shoes
ray ban sunglasses cheap
ed hardy uk
adidas trainers
ralph lauren
chaussure louboutin pas cher
ghd hair
nike air huarache
ray bans
yeezy boost 350 v2
ray ban glasses
coach outlet online
coach factory outlet store
adidas superstar trainers
michael kors
polo ralph lauren
adidas superstar shoes
mlb jerseys whgolesale
pandora charms sale
tods shoes
birkenstocks
celine handbags
yeezy shoes
red bottom
kate spade outlet
kate spade bags
mbt
fitflops sandals
mlb jerseys
coach outlet online
cheap air max
longchamp bags
dansko
adidas sneakers
michael kors uk
adidas yeezy boost
cubs jerseys
ralph lauren uk
coach outlet online
fit flops
louboutin outlet
kate spade purses
pandora charms sale
crfreg
