- May 7, 2012
- 8,594
- 1,819
- 30,935
I think this is getting into nit picking. As long as we understand what the practical application is, the precise term is irrelevant.
Justa answering Buckman's question.I think this is getting into nit picking. As long as we understand what the practical application is, the precise term is irrelevant.
Hi all,
I’m looking for some advice please. I have just bought a 2016 Lunar Cosmos 544 (Quasar dealer special). My previous van had a weight gauge on the jockey wheel, so for this one I bought a kampa gauge. I was surprised to find that with only one small gas bottle in the front the nose weight read nearly 100kgs. The only few bits and pieces in the van are under the french bed which is behind the axle. Given that there is virtually no payload in front of the axle, this weight seems high to me. Could this be right, or should I cast a suspicious eye on a cheap scale? Thanks in advance...
Most likely that it is the caravan that is nose heavy when unladen. When I bought mine it had one Calorlite in the front, but battery, mover, fridge water heater, psu etc are all forward of the axle and cooker too. To drive it home I had to fill the cassette, flush tank and a 10 kg water carrier all at the back. So around 40 kg in all. Most of my kit has to be stored behind the axle. Nothing in the front under seat lockers. I have to get mine to 80kg for the car.I would look at the gauge with suspicion to be honest, Milenco produce one that is reportedly the only one calibrated.
If you can the best method is digital bathroom scales and a stick!
My first nose weight gauge not a Milenco, I bought it from a dealer it used to stick, let's say it would read 90kg, I could give it a wiggle then it would read 75kg and so on, completely inaccurate so binned that and bought a jockey wheel that had a weigh function, again a well known dealer brand, and again complete rubbish so ended up using the bathroom scales method, which is fine if you have the surface and time.Most likely that it is the caravan that is nose heavy when unladen. When I bought mine it had one Calorlite in the front, but battery, mover, fridge water heater, psu etc are all forward of the axle and cooker too. To drive it home I had to fill the cassette, flush tank and a 10 kg water carrier all at the back. So around 40 kg in all. Most of my kit has to be stored behind the axle. Nothing in the front under seat lockers. I have to get mine to 80kg for the car.
Its very important to have enough nose load to maximise the cars ability to control the caravan. Unfortunately these no magic value or percentage that suits all cars and caravans, though the industries guidance of 5 to 7% of MTPLM does seem to produce good results.Could be wrong but I don't think the nose weight will make much differents,, if unmatched..
Hi Darren where about in the lakes are you going in April ?My first nose weight gauge not a Milenco, I bought it from a dealer it used to stick, let's say it would read 90kg, I could give it a wiggle then it would read 75kg and so on, completely inaccurate so binned that and bought a jockey wheel that had a weigh function, again a well known dealer brand, and again complete rubbish so ended up using the bathroom scales method, which is fine if you have the surface and time.
I'm currently buying the Milenco gauge, an expensive item tbh, but my outfit isn't that well a match so the noseweight is crucial for us, first outing on the 18th of April all fingers crossed, another but, we use pitch and store so collecting caravan on the way to the Lakes, normally we would have ample time to load and check everything but due to Covid we havnt been able to.
Hi Darren.H Looks nice might be to hilly for me but I hope you have a fantastic timeNorth Lakes area, a caravan site chosen for location and ease of driving there from Thirsk area
Burns Farm - Lake District Caravans, Camping & Glamping Site | St Johns in the Vale, Keswick
Burns Farm is an award-winning, family-run caravan, camping and glamping site nestled close to Keswick in the hills of the Lake District National Park.burns-farm.co.uk
