Noxious smell
9,669
Is it a gas smell, or something a bit different? If the latter it could be a new burner jet could be required and the fumes are venting inboard as fridges tend not to be very well sealed.
Nov 30, 2022
2,021
1,930
If this problem is only evident when the fridge is on gas then you need to have the fridge looked at by a qualified gas engineer. In the meantime ONlL use it on 230v and turn the gas supply to the fridge off at the multi-valve manifold.
646
I suspect Tony does not have hook up, he said he was going to Granada rally, and also mentions generator
Jan 20, 2023
1,328
1,186
5,435
Pop the fridge vent off on the side of the caravan and see if you can see anything burning or melting. There is a slim chance that a wire or similar has moved and is touching something hot, however as others have said, getting the fridge checked/serviced would be a wise precaution as the sort of smell you describe sounds like burning plastic of some sort.
Aug 12, 2023
685
320
2,135
The vents should have two sliding clips, look from below.
Should be metal cover on burner (bottom right?) which can be easily removed for cleaning. On mine it was undo a screw and slide to left. See Youtube videos on cleaning 3 way fridge burners.
4,473
If its an acrid smell could it be amonia? if it is that could mean the refrigeration circuit has been compromised. It may not be repairable, Get it checked out.
Jun 6, 2006
1,040
260
First question is…..is it a new van?
If it is then it could be the paint burning of the rear of the fridge.
If it’s an older fridge then it could be incomplete combustion, a smell a bit like a dirty diesel engine running, there could be signs of black by fridge vent, this would confirm this
5,505
Glad to know everyone got out safely. I wonder if the issue will be blamed on the mishap with the Granada?
1,711
551
Oh my goodness! Presumably when it caught fire you were already in bed, so terrific that nobody was hurt. (Photo from 1.42 am!) Then you were able to stop the spread and prevent further damage to your or adjacent vehicles! Best of luck getting things sorted!
