Oil filled radiator?
Sep 2, 2024
16
Is it ok to use an oil filled radiator in a touring caravan? Just thinking ahead to cold evenings and hoping to get some autumn weekends away
8,176
Yes it will work from your 240v. They are quite heavy as we have one at home. Convectors give out a nice warmth and are lighter too.
Just make sure you stay within the power supply rating if the EHU bollard. But the caravans Truma electric is 2kw so that should be a guide. Power divided by volts gives amps. So 2kw draws 8 amps steady current. (Close enough )
Jan 20, 2023
1,178
1,019
2,435
We had a small oil filled radiator (from Argos) in a previous caravan due to poor blown air heating at the far end. It used to do a good job but needed switching on early to heat the area properly. Quieter than a blown convector heater BUT as mentioned by Clive, heavier than a blown heater and as with any bit of electrical kit, watch your power consumption.
Reactions: Spinador
4,675
Is there a reason why you do not want to use the gas heater in the caravan for heating?
Sep 2, 2024
16
Just thinking about colder weather and keeping the caravan slightly consistently warmer, the gas heater is ok for a quick warm up but an oil filled course left on low for longer periods
4,006
I have used our gas/ heater, the Thetford Combi boiler, during winter for a month at a time with below 5 c with no problems . Daytime at 24c and over night at 15 c internal temperatures.
Jan 20, 2023
1,178
1,019
2,435
Some caravan designs are awful when it comes to the blown air system. When we had an oil filled radiator as supplementary heating it was in a 2014 Swift Challenger 586, with bunk beds and a dinette at the rear for our daughter. The blown air pipe run to the rear was so inefficient that the air emitted up there was luke warm at best and no amount of butterfly valve adjusting made much difference. Our current caravan also has the ducting for the rear air vent running underneath the caravan but I have just insulated it to hopefully improve warmth in the end bathroom.
Mar 3, 2022
368
281
4,935
We've caravans year round for years.
Off-grid even in the depths of winter the on board heater has proved to be more than sufficient to keep the van cosy and warm.
On the rare occasions we've been on sites with EHU the electric heater has been sufficient to to keep the van warm.
4,006
On my 2013 Truma Combi boiler /heater I have replaced both elements. The first 5 years of use of the van we were going away every 12 weeks for 4 weeks, summer and winter, to France, so a lot of use.
Winter time we used both gas and electric, combined, it seems very efficient, works as designed.
Not sure if this information is of any help to you. But combined use of gas and electric for us is great.
4,766
That really is unacceptable!
My old 2009 Bailey has all the hot air pipes internally.
Why on earth were Swift going backwards in 2014? Another great caravan design defect
Jan 20, 2023
1,178
1,019
2,435
Swift have done it for years on various models, probably because it's an easy/cheap approach and keeps it out of the way. I think a rectangular duct (like a hollow skirting board) run along the bottom of the inside wall would work and be unobtrusive but that'd probably cost a few pence more! I suppose it doesn't affect those that only use the caravan during the summer months but during spring and autumn it really does leave the back of the caravan as a cold-spot.
Aug 12, 2023
644
290
1,135
Some layouts don't allow for running duct internally. Our Altea has short 1m run under floor to reach end with bed and bathroom.
Reactions: GaryB
Jul 15, 2008
3,828
967
.....did you adjust the main balancing butterfly valve at the back of the Truma Ultraheat.
The lever to adjust the valve is usually hidden away and difficult to get at.
It is under the floor of the wardrobe in a Swift 586.
Many people are unaware of this feature whereby heat can be prioritised to the back or front of the caravan.
The underfloor ducting is double skinned.
There is an outer waterproof ducting surrounding the air duct and this provides some insulation.
4,675
On our previous caravans which were Lunars, one had to remove the drawer above the heater to access that lever. It did make a difference, but then I also lagged the pipes underneath the caravan.
Jan 20, 2023
1,178
1,019
2,435
Yes, we tried that as someone on the old Swift-talk forum suggested doing it. It made a little bit of improvement but not much. One cold day I put the heating on for half an hour and the external ducting under the caravan was warm to the touch so even though it was double skinned some of the heat loss was considerable hence fitting insulation on any caravan we have had since.
Oct 19, 2023
548
430
1,135
What do you use as insulation? I have a section 1-2 metres long under the caravan. It's not really an issue heating wise as its only a small 2 berth caravan, but I'd rather conserve energy than waste it.
4,675
I used one of those insulated camping mats cut into strips and tied on using cable ties.
Reactions: Beardy
Jan 20, 2023
1,178
1,019
2,435
This stuff but the 75mm ID version, got it on Amazon. For the bends I use foil bubble wrap.
Reactions: Beardy
