If the site has onsite booster ariel plug ins on pitches. Where abouts in the caravan do you plug it. I have a coax cable but if someone could explain to me that would be appreciated.
If you have an input plug from the caravan aerial to the caravan booster box you can plug it in there or just straight into the aerial socket on the rear of the TV.
Where you can gain entry for the cable in to the caravan from the sites booster supply will probably be the deciding factor as to where you plug it in.
Lisas we use a thin coax cable and just shut it in the bottom of the window. The rubber seals round it and it does not seem to put undue strain on the window latches.
If it will help what i done on our Coachman was to have a lead through the battery box so that we plug straight into either the sat'box or TV ,i made the lead about 5m long to reach what ever we plug into.
