Onboard power supply/transformer with leisure battery
Nov 30, 2022
2,021
1,930
5,935
The charger will supply what it can supply, the capacity of the battery won't make any difference.
Think in terms of your battery being a bath and your charger a tap. You open the tap and water flows into the bath at a certain rate (so many gallons per minute) The size of the bath makes no difference to what comes out of the tap, just how long it will take for it to fill your bath.
Same with your battery charger, it will push out a maximum of 10 amps regardless of the A/H of what it's "filling"
If you have blown up two chargers there is clearly something amiss, so time to get someone in to see what the issue is.
Reactions: Beardy
Jan 19, 2002
1,711
551
Can you report what manufacture is the distribution unit/charger as some are notoriously liable to failure so comments here can be altered to suit.
Look on the internet for a local AWS Technician who will be cheaper than a dealership and usually come to your place to service and undertake any repairs.
As an aside... Your tyres should usually be changed every 5 years regardless of wear, and generally no older than 7 years. Look for the lozenge with 4 digits on the side wall - e.g. 2119 would have been manufactured in the 21st week of 2019.
Oct 19, 2023
639
510
2,135
What MrPlod said.
I often charge my battery with an optimate battery 'maintainer' that kicks out a maximum of 1 amp. Granted it takes a few days but it gets there.
Sep 23, 2023
1,508
666
2,935
Mr Plod,perhaps if the tyres are under 5years that's a positive If however they are over 5years that's a negative 🙂
Jul 8, 2024
On another note. My battery was causing the problem drawing power even though showing it was fully charged
4,473
Unfortunately as you have deleted the original post, this thread now makes no sense at all. Could you reinstate the opening post?
