- Jul 18, 2017
- 16,542
- 5,308
- 50,935
We have all had the issue of the trim covering the joints peeling.  The picture was take awhile ago and it is even worse now.  I know of the solutions suggested using a warm iron to stick it down again, but that only seems to last several months and it starts to peel again.
A more permanent and drastic solution is to use D shape trim like this to cure the issue and stapling the trim down instead of gluing it. However I am wondering if using a glue gun will produce the same results, but the concern here is that in hot weather the glue may start to melt?
What have you found to be the best long term and more permanent solution? Thanks.
