- Apr 20, 2009
- 5,631
- 1,030
- 25,935
Gafferbill said:Gafferbill said:.......you can fix it Kevin
Hope it is not as bad as you first thought.
Told you![]()
I borrowed your cunning plan and kept digging
Told you![]()
Gafferbill said:Kevin...........Do you want another cunning plan?
Something tells me that pesky screw will undo itself again and the squeak will be back.
The little gits work loose when the caravan is being towed and everything is flexing.
It has happened to my caravan a lot!!
Here is the plan if it does work loose......remove screw completely ......inject silicone sealant into the hole and put screw back in and tighten.......remove excess silicone.
The sealant has good adhesive qualities but remains flexible and stops the screw working loose.......works for me.
forestgump said:just let you know kev mine is still lovely and dry he he .may be the red croks?
