Anyone use a pinless damp meter? Looking on the big river £20--£30 but are they any good?
YesAnyone use a pinless damp meter? Looking on the big river £20--£30 but are they any good?
Thanks for that Ian 👍I use both pinned and pinless , all are relative , the main thing is to get to know it and the readings it gives .
One area which can be confusing is the vinyl floorings , they can trap moisture between the underside and the actual floor or it can be real damp ingress.
Thanks for taking the trouble to give me such a helpful reply 🙂
Into the meter, caravan or technicianI had that make of pinned type and found that I got very similar reading as the Mobile tech that services my van, Ironically damp got into it, so I need to get a new one.
Being a sucker for gadgets I was about to buy a pinless one. I already have the same pinned one as you and it's a couple of percent different from my service tech. Your comment has persuaded me to save my money.I've got one of each.
The one with the prongs has two modes - Wood or Masonary. I found it to be good and reliable , mostly for checking our wood but also in the caravan. The prongs don't really make much of an impact.
The pinless one has more modes - Soft Wood, Hard Wood, Masonary and Wall (?) It gives similar results to the pinned on wood but is useless on the caravan walls. I think the vinyl wall covering screws it up.
Not sure what the professionals use but presumably it can work on caravan walls.View attachment 10261
Better luck for you as Hutch got damp in his ( meter).I have the pinned one like Sam but when we brought it last year it was damp free exactly the same results as the caravan dealer .
Well when check next month if we find any it still under warranty with the caravan dealerBetter luck for you as Hutch got damp in his ( meter).
So as no timber it can never leak hence no damp readings??Salop leisure only carryout a visual check on our HT shell Swift Conqueror 480, no damp test report.
I’m talking about Hutch’s damp meter not the caravan 🙈Well when check next month if we find any it still under warranty with the caravan dealer
Totally agree I was surprised they did not carryout a non invasive damp test, considering they did not reduce the service price accordingly, however the caravan has always been bone dry.So as no timber it can never leak hence no damp readings??
Hi Clive apologies got wrong of the stick , I hope Hutch gets a better damp meter👍I’m talking about Hutch’s damp meter not the caravan 🙈
Marker lights is a common place for leaks in Swift vans.So as no timber it can never leak hence no damp readings??
