PMS 5crv2
Sep 5, 2014
Hi, the mains polarity light has just started to come on when the mains lead
is connected also the water heater & fan master not working.
Any advice ?
4,223
Any advice ?
From the symptoms you describe, I suspect the mains EHU cable should be checked, could be a loose wire. If you have any doubts, get it checked by a professional.
4,223
Frankly I can't see how disconnecting the battery would affect the mains polarity light. I still suggest you check for loose mains wiring connections especially in the EHU cable.
Jul 31, 2010
1,285
A poor battery connection causes a high resistance, which could cause the power unit to play up.
However I agree that a full check of mains circuit is required, including the pick up cable.
Sep 5, 2014
Steve,
Yes there was a bit of copper corrosion on the pos connector.
I think that was the problem.
Phil.
