Poolin water on caravan roof
May 3, 2023
78
50
585
hi all, as you all probably know I have hadstroke, and I am in recovery, I am walking about down stairs with a cane at the moment. I am going to put the caravan a seasonal pitch,until I improve a little more But here is my issue, whichwayay would you slope thvan to enable rain water to gently un off.i have an elddis avae 860, it has a rear window and off side rear window. Don't want pooling for a long period of time, particular on the roof straps or joints Any possiblesolutions.
Regards john.
3,612
I try to get a slight slope down to the off-side (right) as this helps the nearside kitchen and shower drain as well as stopping the rain pooling on the roof - it doesn't need much of a slope at all.
2,690
In storage I would store either with a tilt front to back or back to front. But, and just personal preference, if I had a van on a seasonal pitch I would have to get it level otherwise my undiagnosed autism would kick in.
5,294
We have the front slightly raised for run off at the rear as no window there.
2,268
No idea about the pros and cons of a roof cover. Never had one. Perhaps someone else can comment.
4,594
I hope your recovery carries on without any hiccups,
I would tend to have the caravan slightly nose down, but more importantly for us would be the draining of the shower and kitchen sink. .
For several years now I have been contemplating about fitting Roof seal tape to all the roof joints, just to " super seal " the joints.
1,973
1,868
2,935
The roof strap on my caravan is over the bedroom so much closer to the rear. My theory is that it's better to have a slope running from rear to front. That way the majority of the roof drains away from the strap and only the little bit at the back slopes to the strap. But of course the water can/will build up to the same level either side of the strap anyway! So perhaps a slight side to side slope is better as everything then drains off?
I reckon it's one of those questions that doesn't have a right/wrong answer, just different ones :rolleyes:
