Pooling water on carvan roof when pitched
May 3, 2023
78
50
585
Hi all,
When I am on site and the caravan s level, I have pooling rain gathering on the roof.
Any remedies or suggestions lease.
Regards John
7,961
Other than putting an Acrow prop inside 馃槺there's not much you can do other than put a slight slope to the caravan in whichever axis suits you best. But that may cause problems on sink or shower drainage, hob, etc. If the water pool is away from seals and joints it鈥檚 not going to do any harm. When you get home then just put a slope on the van along its longitudinal axis and water will drain away.
May 3, 2023
78
50
585
Hi Clive that's what do I will check the rooff to see the if the pooing is clear of he roof straps .
Thanks again john.
Jan 20, 2023
1,134
977
2,435
The combination of flat roofs, roof straps (or tapes) and raised edges sees water pooling pretty much on all caravans to some extent. I just ensure the roof is always clean to help water to flow as efficiently as possible. When we're away it's impossible to avoid but when it's stored at home I park it with the front dropped as far as possible, but I still get some minor pooling behind the front roof joint.
May 3, 2023
78
50
585
hi garythanks for that I have already re sealed the roof straps. Looks like it is what it is unl I get home,
Regards john
4,582
We have the Buccaneer which is from the same stable as your Avante. We also have pooling issues and to get around it, we have the nearside raised very slightly. When in storage the front is a lot higher than the rear to allow run off to the rear.
Reactions: toad a caravan
3,765
1,507
Not a remedy but a question, why is there any concern it water pools on the van's roof during on site use?
They ought to be sealed, if not then there is a bigger problem, one that does need a remedy.
4,582
There is a factor called wind that can blow excess water over the rim of the window as it is unlikely that roof lights or windows have a perfect seal.
3,765
1,507
Not a situation that I have ever encountered nor can see being at all likely.
I would expect the wind to simply move the pooling away, even shedding it over the van's walls, rather than create a free surface water head sufficient to climb an aperture's coming.
Its an area I would have thought the component designers would have thought of and addressed that possible issue, adopting an adequate upstand.
Reactions: borderbilly
4,582
They have an Avante similar to ours which is why I know about the wind factor and water pooling on the roof when the caravan is completely level.
I should mention that when the skylight was fitted, the manufacturer never used a flexible sealant so skylight surround cracked allowing water in anyway. This was a common fault on Elddis caravans. However after the repair, on two different occasions in high wind we had an issue. Not serious, but it allowed water drips to be blown into the caravan.
Also they want to put the caravan on a seasonal site so worth taking wind into account.
3,765
1,507
It would happen also whilst travelling in rain conditions
Does it pool when towing, rather than simply be moved away?
Again, if it happens it reflects very badly on the component design, if it is unsuitable for towing in the rain.
Dec 27, 2022
360
233
1,935
Water on the roof has caught me out twice whilst deflating the locknlevel and removing the wheel lock. The run off spot is just in the wrong place 馃槻
Reactions: Danddandy
3,765
1,507
Owning a Gobur Folder is much the same, though there it can be a real drenching. That's, bad enough in itself but should the wife also be helping, or simply close "managing" you, one is forced to learn rather quickly!
Reactions: GUMPY
May 3, 2023
78
50
585
Hi trust me pooling water from experience will find the smallest of cracks or fractures in the grp plastic of what is used to build caravans oof today. And your warranty will not help.
Regards John.
4,582
Regards John.
We claimed for the skylight above the bed when the surround cracked allowing water into the caravan. The caravan was about 4 years old at the time and it was replaced free of charge as it was a fault there from day one. This applied to all Elddis caravans of that era.
May 3, 2023
78
50
585
ingress was on the rear roofstrap twosmall cracks. Eldiss said the only part warranted was the bonded roof strap on the solid warranted cracks were they were not covered by the warranty wanted 拢4000r the repair.elldiss to supply panel for free it rthas not an admission of guilt I do not know what is..dried evethythng out and repaired and re bonded myself ewithiy sikka flex no further issues.
Rega4ds John.
2,350
We had some pooling of water on our Abbey we raise the nearside up not by much and in storage the front of the caravan was higher then the rear this would allow the rain water to run off .
