Poor design TV aerial system
4,799
No terrestrial TV last two weeks away😥
Did a structured continuity test from the aerial via the amplifier back to the cable TV end. Dead between the amplifier and TV🤬.The cable disappears into a hole in the ceiling and comes out of another hole 6 feet away. Solution. Install a new cable. Impossible to pull the old one out.
After removing two panels and the microwave, eureka. Found the problem . A cable joiner behind the microwave had come apart! Must be all the years of vibration. A quick clean up and retighten, all working again.
Why on earth Bailey didn’t use a single section is beyond me. How would you know the join was behind the micro wave. Very poor design again 🙉IMG_1507.jpegIMG_1509.jpegIMG_1506.jpegIMG_1508.jpeg
4,708
Bailey are doing you a favour by getting the grey matter moving so you should be thanking them for their wonderful design. LOL. 🤣 🤣
4,799
There really is something wrong the way caravans are still designed to be failures.
The Prof mentioned this point yesterday.
Every time we go away something breaks , I honestly can’t remember when we had a breakdown free holiday. Last week the grill started playing up. More dirt / rust in the gas pipes.
A tap with my mini hammer fixed it. But I expect by the end of the season I will have to remove and strip down and clean the grill for the fourth time in 17 years🙀.
183
124
1,635
I often think people who design things should be made to use them and maintain them. I used to work in facilities management and had hundreds of arguments (debates) with architects during fit outs who would propose something that looked lovely but was virtually impossible to clean or maintain. Generally they stared into space as if I was talking a foreign language.
4,708
Didn't the Jag XJ have a seal between the gearbox and engine costing less than £1, but thousands to remove the engine to access the seal? That is very poor design with no forward thinking. I think the Discovery had a similar issue?
8,238
Some cars particularly with small engines require the engine to be removed to change the cambelt. Wet cam belts do go longer than dry cambelts but as Stellantis have revealed some of their 1.0 and 1.2 Puretech engines haven’t given the service required. Hence the recent compensation scheme going back to 2012 on some cars.
Sep 4, 2011
335
133
18,735
Yes I can confirm the Discovery did,bought it new and had to replace when a few months out of warranty. The worst new vehicle I ever bought. New gearbox at 6 days old, every time you let foot of accelerator it jumped out of gear.Fortunatly warranty did cover that.
Feb 13, 2024
926
578
1,135
Should have bought a lunar 👌
Sam Vimes
2,288
1,798
I agree....more and more I see form replacing function.
Sam Vimes
2,288
1,798
My daughter's Feista has the wet belt system. She's recently spent just under £1k having it replaced.
My Qashqai has a regular dry belt that needs changing at 144k miles if normal driving.
72k if you drive it hard, whatever that means.
4,799
The fatally flawed Eco boost wet belt engine. I’d ask Ford for every penny spent .
8,238
At least a dry belt system doesn’t risk polluting the oil assuming it’s lubricated by the engine oil as many are.
8,238
I think some Ford engines do have to come out for a cam belt change. So perhaps the £1000 reflects the material and labour costs. Our Nissan Note was £400 every four years or 40k miles. And that was a dry belt system. It’s not a question that buyers tend to ask. I changed to petrol and cam chain five years ago for our cars.
4,799
The Eco Boost wet belts shed "hairy " bits which blocked oil ways feeding critical bearings causing premature failure. It's costing Ford a fortune in the USA fixing them. If that happened to Sam's daughter's car ,Ford should pay.
8,238
Stellantis 1.2 and 1.0 Puretech have a similar problem. Hence the extended warranty, repairs and recently announced compensation scheme. But only for those owners that can show the cars have been maintained fully iaw Stellantis service requirements. Our granddaughter has a 2014 208 with the 1.2 puretech engine and she’s doing 10000 miles per year. Worried of Wiltshire !
