Hi Patrica,Patricia,
No, not a stupid question.
An inverter is a device which converts 12VDC from a leisure battery to 230/240 VAC.
Small ones such as 150/300 wats are relatively cheap and could be used to power low wattage devices such as a mains TV, cd/radio etc. when you are not on mains electric or when you do not want to disturb your neigbours by running a generator.
Larger ones of 1000 watts upwards tend to be expensive but I use my 2000 watt one to power the microwave oven and the electric kettle.
As an aside, I spent the last bank holiday weekend on a CL and 4 of the 5 caravans were running generators, 3 Honda & 1 Robin and they could hardly be heard over the ambient bird song, cackling geese and other livestock sounds.
John,Hello Rod.
I appreciate that you are trying to be considerate by only using your generator between certain hours. May I offer what I hope will be constructive criticism based on your posting of 2 Jun 2005 08:01 PM.
You state that you use gas for your fridge and water heater when the generator is off, but does that mean you run the generator to power these items at other times?
Cost for cost, the fridge and the water heater are far more economical to run on gas except where you have a mains hook-up. Gas appliances must be at least 70% efficient at converting gas to useable heat. Compare this to a portable generator, where small internal combustion petrol engines are at best 15% efficient fuel to mechanical energy and then about 80% mechanical to electrical (15% x 80% = 12% best overall and typically only 8 to 10%). The actual electric heating elements in the water heater and fridge are virtually 100% efficient, thus they do not influence the above estimate of efficiency.
In addition to the above, the water heater (assuming either Carver or Truma models) will stop using gas when the water reaches temperature, where as the generator will continue to run albeit at no load. So there is yet another saving when using gas over generator power.
I would strongly recommend that you run your water heater and fridge exclusively on gas (except where a mains hook-up is available), and perhaps limit your generator usage to the occasions where only 230V ac will provide the power you need.
