Hi and welcome to the forum
You haven't told us the age of your caravan which does affect the interaction between systems.
Touring caravans 12V dc systems need a power source to run the 12V appliances and lights. Traditionally a caravan is expected to have a 12V leisure battery fitted to be the power source.
It was in the 1970's when caravans began to sold with Mains power options, which included a 3 to 4 Amp battery charger. the type of chargers were not neither smoothed or regulated and they needed a 12V lead acid battery to help limit the wild voltage swings these chargers had. These could easily over charge a battery.
By the mid 1980s The chargers began to be configured as "voltage regulated" to protect batteries from overcharging, but they still only had around 3 to 4 Amps of current capability. and were unsmothed so they also were still expected to have a 12V battery to provide the smoothing and extra power for higher current devices.
As time has gone by, we have adopted more items of equipment that need 12V dc power so the demands on the 12V supplies in caravans has grown and outstripped the contemporary chargers capabilities.
The 90's saw advent of Switched Mode Power Supplies. (SMPS) these were capable of supplying about double the current 1980's units, and now you might get away without a 12V battery, but you still needed to be frugal with 12V powered items. With two or three lights on here may not be enough current available from just the SMPS by itself, so it was still expected to have a 12V battery.
Since circa 2000 standards have changed a little. Caravans now have "Smart chargers" or Power Supply Units (PSU) these have greater current capability (typically 12 to 16A a few with 20A) but are optimised towards recharging a battery and managing them better. So the advice is you may get away without a battery by using the SMPS's output but it is still advised you may need a battery even when using an EHU. And of course you will definitely need a larger battery if you do any off grid activities. or have a caravan mover.
and still need a battery, But, with latest caravans if you are using EHU you can get away with a smaller Ah battery.
