Powrtouch classic problem
Feb 5, 2022
7
515
I have a powrtouch classic which I have not used for some time until this week. The leisure battery is fine and the remote battery has been replaced. However, when I try to engage the mover nothing happens other than a slight electronic sound. The green light is on in the control box asxit should and the remote seems to light up as it should too.
I have searched online for answers but can't find anything similar.
Any advice or suggestions would be really appreciated.
Nov 30, 2022
2,010
1,913
I have a spare controller if you find that's what the iissue is and need a replacement.
2,334
Check that the battery terminals are tight. We had a similar problem, leisure battery fine but one terminal a bit loose. Worked fine once tightened.
mel
9,464
Just adding to Mel’s advice you should also check that the cables in the terminals are tight too.
Reactions: Mel
5,498
Plus Clive as we have both experienced the actual spade connectors on the two motors. Clean them up, spray with electrical contact spray. Crimp the female bits for a tight fit and with a bit of luck….
9,464
Dusty
I could wax lyrical about the gaiters that perish and allow water ingress, and my “patented “ approach to ensuring it cannot happen again. Must see if I can find the link.
Here it is:
7
515
Thanks, everyone. I have not managed to get back down to the caravan (in storage) to check these out yet but will give you an update when I do.
