Pressure Switch
I have a Avondale Perle custom in which the water pump does not work all the micro switches are ok and there are no water leaks so I think the pressure switch is not working wherre can I find it
James, if you have taps with micro switches then you will not have a pressure switch. If you are sure that the switches are ok, [how do you know?],and that there is power getting to them then check with a volt meter for supply at the pump connection.
James, how do you know there are no leaks if you cannot pump water into the van? ray
