Preventing flat spots on tyres
Hi Folks.
I visited the dentist yesterday and was flicking through a well known classic car mag in the waiting room,I came accross an article on preparing your classic car for winter storage which recomended you inflate the tyres to the maximum psi stated on the sidewall to prevent flat spots then deflate before use again.I suppose i can see some sort of logic there and wondered about the same for caravans.What does everyone think.
Regards
Sean
The subject of flat spots comes up quite regularly.
There are a number of things you can do, remove the wheels and fit "Winter Wheels", or an old set of wheels and tyres.
Or raise the van on axle stands to take the weight off the tyres and axle.
Inflating to max sidewall pressure really does not do much, you still have a small flat spot.
However, with all the talk about the subject I have yet to meet anyone who has actually suffered flat spots on caravan tyres.
Going back to raising the van on stands, this is the best option for the van as it allows the axle suspension rubbers to rest and regain their original setting, reducing axle suspension wear.
Flat spots are only a ride comfort issue during the first few hundred yards of driving after an extended period of rest. After a short while the flat spots will iron themselves out and disappear again.
What concerns me are those people with the Alko thru the wheel lock - have only about 4 places they can secure the lock putting
the weight of the caravan on excactly 4 places each time. Unless the have the wheel with lots of spokes which give u about
6 or 7 spots to place the lock.
That's why mine is on adjustable axle stands, its locked & secure & off the floor, take me about 10 Min's per side,its a job well worth doing.
Sproket.
The problem i found with axle stands was the lack of fine adjustment, i ended up using concrete blocks, packed with wood on top, with a rubber sheet being the final packer, to prevent any wear to the galvanising finish.
now i just take the wheels off and use wheel stands.
Ray
These axle stands are on a screw thread, so you can adjust to what ever size you req,( depending what size you buy ) & the large foot prevents sinking, car axle stands have limited adjustment.
Sproket.
