- Mar 7, 2008
- 33
- 0
- 0
Hi all, my 2006 Sprite Quattro has a car stereo sized blanking plate fitted in the front left corner, on the facing between the side locker and the front locker. I have discovered a wiring loom behind this which has two plugs which match up perfectly with the radio/cd I wish to fit, there are also speaker wires, on both sides of the van ready to go, I thought this was all going too smoothly, and then, there was the catch, they have supplied everthing apart from an antenna, or antenna cable.
So, do I have to fit an antenna and drill a hole through the wall for the cable, which I'm not too keen on for leak/damp reasons, or is it possible to tap into the tv flying saucer antenna, will this pick up FM, or is there another solution?
Thanks, Jim
Thanks, Jim
