- Sep 26, 2018
- 732
- 291
- 19,135
Hi all,
Been down to the van in prep for our next trip. The intention was to "puriclean" our water system, which was last active in mid March. So, mixed up the cleaner, added to the Aquaroll, closed the drain valve on the Alde, hot water shower (furthest away) turned on to bleed the air out, Whale pump in Aquaroll on and working... We got none of the usual gurgling and spitting, and no water out of the shower. After a short time the pump cut out and then was running a short time roughly once every 9 seconds, but still no water.
As we don't drink the hot water we decided just to do the cold side, and that worked fine. Water drawn through, and all left to stand for an hour...
Had a good look around the Alde, and there's a clear breather type pipe off the top of the boiler where the cold feed enters but that was clear
As we were waiting we went off for lunch, and returned an hour later, and pumped the Aquaroll out (through the cold only),and refilled AR to rinse through as required. This time the hot behaved differently and we got a flow out of the taps, although the kitchen tap seemed very much a poor flow (from both H&C) whereas bathroom was fine on both.
There's a small pressure accumulator and no filter that I can find... Can anyone tell me whether there is anything I've missed? It could obviously have been an airlock, but ??? Any pointers gratefully accepted!
Larry
Larry
