Apr 25, 2010
We have an ABI Nightstar c1994 which we have had for three years. The past two seasons we have had a problem with the taps. We do not use the heater as water does not flow from the cold tap in kitchen or bathroom, and only runs from the hot tap for a few seconds then flow slows to a stop. The bathroom hot tap sometimes works better but is frustratingly unreliable.
Also the flush does not work on the thetford electric toilet, is this easy to fix. Thank you in anticipation
937
The water problems are probably due to the taps being blocked by carbon granules from a disintegrated water filter.
Hot water slowness is more than likely due to a damaged cold water inlet on the Cascade water heater, and the toilet probably has a seized pump.
I would suggest you get a mobile engineer to sort it all out .
Apr 25, 2010
thanyou for that info. I have tried to find a mobile engineer without much success. Our van is near Kennford, Exeter. Any ideas?
