Hi , This is an ongoing problem we’re having with our 1992 Abi ace globetrotter but I still haven’t managed to sort it , we’ve been having problems with the kitchen taps in particular needing the washers changing since we got the van . This year doing the regular checks before going away we found one the tails for the pipe had come off , so changed them as a pair ( thinking we wouldn’t need to do anything else while we’re away )
The first 2 weeks we’re ok then they started leaking again - up to this point all taps had been working ok even the bathroom ones. So took the middles out found one split and a tear in another , so changed all of them. After that when you turn on the cold tap in bathroom the kitchen tap starts going as well , then a drip started in the kitchen which was emptying the hot water tank. Took the middle out of hot tap , both seals ok , took middles out of cold to find the angled one split .
So changed all the seals again to find it’s still dripping. So as it’s the last couple of days we’ll turn the pump of when not in use.
So , has anyone had similar ? Would I be better of changing taps for newer types ( bearing in mind these were new taps again this year) any ideas ?
Thanks , Ads
Thanks , Ads
