I picked up my new Series 7 Pageant Bretagne yesterday & flicking through the instruction manual I'm not quite clear where the various switches should be when connected to my towcar (full 13pin electrics) to allow the fridge to work & the battery to charge.
Should the 12v master switch be on? There's no (car/van/off switch).
I understand that the fridge should be switched to the 12v position but there's a sentence in the manual that says the engine should be running otherwise the battery will be flattened. Does this mean the car battery or the van battery? Surely the fridge should not be drawing from the car unless the engine is on?? Does the fridge draw 12v from the van battery until a car is connected & the engine switched on? This seems daft as there's a real danger of wrecking a leisure battery if you forget to switch the fridge off?
