i have recently changed all my lightbulbs in my van to led's and am pretty amazed with the results, now if i was to turn all 13 lights on i am using a little less power than i was if i had just 2 of my old lights on also they are just luke warm as against untouchable hot as they were, really dangerous i thought, also i have no loss of light in fact the light they prodce is a whiter light so seem much brighter and spead of light is so much better, over the bed head i have two down lighters for reading etc., and they got really hot on your head, i fitted warm white led's to them (as against white in all the others) and the light from them is really nice and good to read by with no heat or glare with good spread, not spot as before.
Happy day's but with one small problem, i have three downlighters connected together with a dimmer, but they can all be switched individually ,they are spaced across the front of the van, we use these in the evenings to read by over the lounge area, the radio is also fitted just above one of these but i believe the lighting wires for all three pass in the same area as the radio wires and i am getting a fuzzy reception on the radio whilst the lights are on, this clears in graidients with each light that is turned off, with all three off it is back to normal, i can only assume that the radio is picking up this interference from the lighting wires, it never happened with the old bulbs but i aint going back .
does anybody know if i could maybe fit a suppresor or something in the power supply to the radio or maybe it is the speaker wires i should be thinking off.
Hope you can help ............ Geoff
