I'm after a bit of advice regarding Air Pumps (12 volt)
I have the Kampa Rally Air awning (260) and use the supplied hand pump to inflate it.
I watched a chap a couple of weeks ago using a electric pump and was impressed how much easier it seemed.
So having looked on the net I've come across two versions of a "Bravo" pump one being two stage the other I presume one stage. Both can be preset to cut out when the desired pressure is reached.
From the prices I've found there is roughly a £30 difference between the two. £100ish. and £70 ish.
Mind you the one I saw being used was in fact yellow and the one I think I've identified on the Internet the same, is again approaching £100.
So can anyone recommend from Actual Experience which I should go for.
I don't hold out much hope of picking one up second hand I could only find new ones from a search.
Best wishes to all
Brian
Best wishes to all
Brian
