Pros & cons please
Sorry Daniel,The only con I would say is the initial cost of the bottle the pro is you can fill it up your self at any petrol station that sells LPG just as you would fill up your car if it ran on LPG.
Well that contradicts Gasflow refillable LPG comments on there web site you just fill the bottle at the petrol station as you would any other fuel it is in effect the same as filling your lpg tank in your car if you have one the same connections.Sorry Daniel,
Many petrol stations are not allowed to refill portable LPG containers for insurance and safety reasons see below.
Hello Dave,Sorry Daniel,
dave
Like most things we do in the UK there is alot of hot air generated around your topic. look on Ebay there is all the equipment you need and it costs about
John LHello David,
I have looked at the Ebay listing (which has finished now).
Whilst the product seems to allow the user to refill Propane bottles with POL connectors, its use in the UK on garage forecourts is illegal, a situation that is obviously recognised by the seller who suggests doing it in the boot of the car, I guess to avoid being observed. I am not sure what action a forecourt owner can take if you are discovered, but I am sure it would involve severe sanctions.
That practice is highly dangerous, as the gas vapour is heavier than air, and would pool in the boot or seep into the saloon, where there are many potential sources of ignition.
There are also some minor differences between the standards of the 'POL' fittings depending on which market they are manufactured for, so a slight mismatch could have dire consequences.
I commend the seller for posting the warnings about being competent, but unless you have been trained and assessed as competent, it is almost certain that the Health & Safety Exec would consider you to be not competent. - for example do you know what action to take if you do have a spillage or leak?
I would remind you that if the HSE prosecute it is always under Criminal Law as opposed to civil law with the consequences that this entails.
It is certainly illegal to refill rented bottles unless you are licensed by the owners, and as an individual without the necessary inspection and testing facilities that is unlikely to be granted.
No to your last. also they do not know I use them for my Cadac at home , but they did replace them when my workshop got cleared out recently.Hello again David,
I am more than aware of the refillable types used on lift trucks, and that actually illustrates my point. These tanks are filled by authorised personnel, who will have received training and been assessed as competent to complete the task. Insurers are insistent on this.
The tanks are not 'hidden' in a car boot, they will be filled in a correctly ventilated place approved for the purpose, so that filling is conducted in a controlled manner.
The bottles used will have been approved for this type of filling, and if rented, the owners will have licensed the company to fill.
This is not an adhoc arrangement, it is well controlled, which is why so few accidents do occur in the UK.
LPG like its cousin petrol is highly combustible, but it does require different handling, so knowledge of using petrol does not automatically endow the user with an adequate knowledge of handling LPG. It is by definition not 'common knowledge' or 'common sense'.
You do not make it clear if your Dutch friends were refilling their bottles in the UK at filling stations, but it is highly likely that the filling station was not aware of their activity, or possibly the forecourt attendant may have failed to enact the company rules on such activity with regards to safety, insurance, and competence.
The HSE along with the petrochemical industry issue guidelines, but sadly in most cases the HSE only become involved from a prosecution angle if an incident has occurred.
I am not against private ownership of bottles in fact I have had some of my own, and it sounds as though like me you have access to a refill station at your place of work. This is fine provided you are assessed as competent to use the facility, and of course it I properly accounted and paid for. You will of course also have made proper arrangements to have your bottles tested for safety on a regular basis. Have you told your caravan insurance company that you are using your own bottles?
