If you have the flat round Status antenna, then the 'spike' unscrews easily, and this may be enough. If you need to remove the rest, it lifts off easily after loosening one Allen grub screw. You will need to disconnect the coax inside the van and probably remove any coax plug in order to feed the cable through the base fitting (which remains on the roof)
