Remove window
Oct 25, 2017
9
Morning All.
My friend has a 2000 year Coachman Amara 450/2 and has just discovered that the small front window has delaminated completely.
The problem is I can’t removed the window, having lifted it as far as it will go it won’t unhook from the rail and as the windows sit in a recess it won’t slide out either.
Ive seen other posts where it been suggested that the rail should be removed, now what I need to know is how….
How do I remove the rail, I can’t see any “fixings” , any help would be appreciated.
My friends are both in their late 70’s and purchasing a new replacement window is expensive.
Thank you for your time.
Jul 15, 2008
3,645
669
......you need to lift the window to a more horizontal position before it will release from the rail.
There is a sweet spot around this position....too high or too low then it won't release.
Oct 25, 2017
9
I’ve tried this and it just won’t release the window, on another forum someone said that Coachman windows don’t release this way….however I will go and give it another try.
Cheers.
2,890
Erflady, the way Gafferbill describes, is the way my dealer replaced my 2010 Coachman 545 front middle window.
GAS
BANNED
Jun 5, 2015
76
33
18,585
I took a window out of my old van to replace the rubber seal and sure I had to unscrew from the rail ... ??
GAS ...
