Renault Koleos Dymanique Sdci 2.0L 150 FAP 4x4 auto
Sep 22, 2007
6
Does any one have a Koleos Dymanique Sdci 2.0L 150 FAP 4x4 auto?
We have a sterling europa 495 and wondered if this outfit would be ok for this car?
Been to have a look at one today to replace my ageing volvo v70 auto, the car is really a very good runner.
The dealership cannot tell me if the car matched my caravan and i am too damn thick to work it out :)
Any advice would be greatley recieved
Mark
936
From What Towcar website:
Renault Koleos - 2.0 dCi [4WD] (110 kW/148 bhp)
Date of manufacture: june 2008 - up to now
82%
1469 kg 1785 kg Important for safe towing is the weight ratio between Car and Caravan. The weight ratio (loaded caravan / kerbweight tow car) for the Renault and Sterling is 82%. The match between car and caravan is perfect.
Sep 22, 2007
6
Thanks Damian -Mod! Hope you dont mind me calling you Damian-MOD!
I have had a look at the website , my only concern is the list only states auto 2WD and does not list auto 4WD 150bhp?
Both the dealership and i have looked and cannot quite work out which is the car we are possibly going to purchase?
Hence my blooming confusion!
Once again
Thanks i really apprecaite the assistance.
936
The problem with Renault is they use a mind defying system to arrive at , normally, a ridiculously low tow weight.
You will need to be very careful and study the detail in the Tech Spec of the vehicle.
I think the Auto has a lower tow limit, most do.
Renault, unless they have changed, give a kerbweight accounting for just the driver, add pasengers, fuel etc and it all gets very confusing,as you have already found.
Maybe Lutz has more up to date info if he reads this?
857
I'm sorry, I can't be of much help because the UK Renault website no longer lists the Koleos. I tried the both the French and the German Renault websites and they still show the Koleos, but as it is apparently no longer offered as an automatic in both countries (at least the websites show no reference to the automatic) I can only find details of the manual version.
Koleos Dynamique dCi FAP 150 4x4 (MANUAL):
Kerbweight: 1730kg
Max. GVW: 2300kg
Max. Towload: 2000kg
Gross Train Weight is 4300kg
As I said, this data is for the manual, but the dealer should be able to get corresponding details off the automatic that Sapper is interested in by looking at the VIN plate and these details will be the only source of authoritative information anyway. Always rely on what's on the VIN plate. Data found anywhere else is for guidance only.
ps: I've since found a couple of independent websites both quoting a towload of only 1350kg for the automatic. That's a lot less than the manual's specification, but I don't know how reliable those sources are, so the figure needs to be confirmed.
Mar 10, 2006
3,274
47
That data sounds ball park to me.
The xtrail auto will tow around 1300kg, the manuel 2200kg.
Aug 4, 2004
4,343
Damien is right in what he says about the auto versions. The braked towing capacity is normally a lot lower than the kerbweight so I suggest that you be very carefull. Why don't you ask a Renault dealer before committing yourself? As an example we were looking at a Peugesot 3008 1600cc diesel auto with a kerbweight of 1500kg. The maximum braked towing weight was 1100kg with energy saving tyres and 1300kg with non energy saver tyres! the auto gearbox on it was a joke as it seem to lurch between the gears.
In order to get around this as it chnaged gear you had to take your foot off the accelerator. If towing a caravan when it lurches (slows down) between gears, the caravan woudl brake but then the car is trying to pull forward at the same time so lots of fun and games. Caravan members on the Peugeot forum recommended that when towing to select the manual mode and change when appropriate. Sort of defeats the purpose of buying an auto.
I know that Peugeot, Citroen and Renault use the same transmission so they woudl all have a smilar problem, but have no idea on the Kaleos.
3,922
Yet again a third party tow matching web site has been shown to be inadequate.
The calculation is not difficult, but you do need to get reliable data about limits, and that can only be accurately gleaned from the Vehicle data plate, registration document, or the manufacture by quoting the vin plate number. You should also be able to use the vehicle hand book, but I have recently found both printing errors, and the fact that many handbooks are not model specific.
Aparently the Koleos is based on the Nissan Xtrail,
Apr 26, 2010
325
please check with your dealer if this is the correct one
Dynamique dCi 150 4x4
Basics
List Price
£19,910
Body style
4 X 4
Gearbox
6-spd
Doors
5 doors
Seats
5 seats
Engine
Engine Size
1995 cc
Cylinders
Valves
16v
Fuel
Diesel
Emissions Rating
EU4
Performance
Top Speed
115 mph
0-60 mph
0-62 mph
10.4 s
Power (bhp)
150 bhp
Power (ps)
Torque
236 lb ft
Miscellaneous
Kerb Weight
1655 kg
Gross Weight
2300 kg
Warranty
3 years / 100000 miles
Service interval
12000 miles
Fuel tank capacity
65 L
Maximum towing weight
2000 kg
Running Costs
MPG Urban
31 mpg
MPG Extra Urban
45 mpg
MPG Combined
39 mpg
CO2 Emissions
191 g/km
VED Band
J
Insurance Group (1-20)
10
Insurance Group (1-50)
Other versi
Dimensions
Length
4520 mm
Width
1855 mm
Height
1695 mm
Wheelbase
2690 mm
Boot capacity
450 L
Equipment & Options
Power Steering
Standard
Central Locking
Standard
Alloy Wheels
Standard
Air Conditioning
Standard
Front Electric Windows
Standard
Rear Electric Windows
Standard
Metallic Paint
£395 Option
Front Seat Belt Pretensioners
Standard
Driver Airbag
Standard
Passenger Airbag
Standard
Front Side Airbag
Standard
Alarm
Standard
Immobiliser
Standard
CD Player
Standard
RDS Radio
Standard
936
Whilst trying to remove the TRIPLE post of the vehicle specs (PLEASE only submit ONCE, it takes time to come up on the forum!!), it also inadvertently tookout a reply by Lutz which said the figures quoted in those specs were definitely for the MANUAL version, NOT the Auto .
Sorry Lutz
Sep 22, 2007
6
Thank you to everyone who has given me some very very useful information, i really do appreciate your comments.
At the dealership yesterday i was not 100% and my gut feeling is telling me my Steling Catravan is too heavy for the Koleos!
So back to the drawing board, i need to replace my Volvo V70 D5 auto is too low to get in and out, as i have a back & Hip problem, thanks to the Army
936
Having endured (yes endured IS the right word) a Renault for 7 years of hell I would never look at another one.
However, back to the point, why not have a look at the Sedona (unless you are really after a 4x4)
They have a high up seating position, are huge in internal space and great tow cars.
I have had my 2004, 2.9 diesel for just over 18 months now and it is effortless (and has not broken down once), very comfortable and I wish I had spent my money on one in the first place.
Sep 22, 2007
6
Greetings,
Decided against the Koleos and went for the Landrover Freelander TD4 SE 2.2 instead .
Picked up the car Friday and on Saturday involved in a Road Traffic Collison
, car now very poorly ill and wating for the insurance company to sort out PRICELESS!
Thanks to everyone for your advice.
MArk
(soon to be a civilian) cannot wait:)
