Renault Scenic III (2009 - 2016) towing mirrors
Jul 22, 2017
Hi everyone,
Please forgive me if this has been asked before but if it has I can't find it.
Has anyone else got a Mk3 Scenic and if so what towing mirrors do you use?
I'm having a right mare finding any that will fit. The clips on most seem to big to fit between the cars mirrors (the glass) and the surround.
Any help would be very gratefully received.
Cheers,
Andy x
1,818
We do not have the Scenic but like a lot of people seem to find the clip on mirrors we used to use did not stick securely to the new cars larger ones and we have now returned to strap on ones. The best answer seems to be check with your local dealer or Halfords if they will let you try them out before you buy to see if the ones you like will fit.
Jan 19, 2002
1,678
521
Had the same problem on a Focus - but by carefully arranging the clips the ext mirrors slotted into the bottom of the ford mirror with the web straps into the top. No way would they fit in the 'standard' way with the main clip between the top of the glass and the housing.
Don't know if it helps any, so hope you can find a good fit for your towcar.
Aug 23, 2009
3,167
The new Milenco ones may fit but any dealer should let you try what they have in stock before you buy.
